Hello,
I sometimes recieve information with 100ds of blocks.
Those blocks are in layer1 but the text in them is written in layer2
So, how can I change globaly that text layer (layer2) in the block to layer1? Because now I need to turn off two layers layer1/2 to turn off all the info.
Thank you in advance.
Try the Laymrg command- this will merge all entities on a layer into a different one, not just the entities in a block though.
