Dear all,
I would appreciate a help with 3D coil drawing (step by step). I am using Autocad Mechanical 2008.
Thanks in advance
Command: _Helix
Number of turns = 5.0000 Twist=CCW
Specify center point of base:
Specify base radius or [Diameter] : 5
Specify top radius or [Diameter] : 5
Specify helix height or [Axis endpoint/Turns/turn Height/tWist] :
kencaz
How did you make the gif video did you do use Camtasia or some other?
