SelectSimilar: for those running older version without it
alanjt
Per a thread someone posted about having issues with Select Similar.
Nothing special. I was killing time last night (finished my book and wasn't sure what to read next) and I thought I'd scratch this out for the less fortunate...
(defun c:SelectSimilar (/ ss lst)
 ;; Select Similar for those that don't have it
 ;; Alan J. Thompson, 07.06.10
 (vl-load-com)
 (if (setq ss (ssget))
   ((lambda (i / e ent)
      (while (setq e (ssname ss (setq i (1+ i))))
        (setq ent (entget e))
        (setq lst
               (cons (append '((-4 . "<AND"))
                             (vl-remove nil
                                        (mapcar (function
                                                  (lambda (n / p)
                                                    (if (setq p (assoc n ent))
                                                      (if (eq "*" (substr (cdr p) 1 1))
                                                        (cons n (strcat "`" (cdr p)))
                                                        p
                                                '(0 2
                             '((-4 . "AND>"))
                     lst
      (sssetfirst
        nil
        (setq ss (ssget "_X"
                        (append '((-4 . "<OR"))
                                (apply (function append) lst)
                                '((-4 . "OR>"))
     -1
  • 4 weeks later...
Nice Work, And now it is avaliable in Autocad 2011
Regards,
Thanks. It's pretty much always been available in the vertical options, and I think you can get it for 2010 in you are on subscription.
Nice one! Thanks for thinking of us
Thanks and you're welcome. As I said, I was killing time. I'll never use it (Civil 3D has it built in), but I wanted to help those running older versions of CAD.
  • 1 month later...
  • 2 months later...
I take it there is no way of doing anything similar for us paupers who only have LT is there? At the moment I have to use the Qselect option which is time consuming when you have 100+ blocks and colleagues who use weird block names :ouch:
Not without some kind of LT addon.
  • 2 years later...
  • 5 years later...
