muthu123
(read (strcat "(" "1.5X250X600" ")"))
muthu123
When we use this fucction
it will return
(1).
But i need like this
(1.5X250X600)
Please help and thanks to Mr.Lee.
Yours,
Muthu.
Share this post
Link to post
SanganakSakha
From help:
The read function parses the string representation of any LISP data and returns the first expression in the string, converting it to a corresponding data type.
Why not simply use (strcat "(" "1.5X250X600" ")")?
Or if you want to display the value at command prompt without quotes:
(princ (strcat "(" "1.5X250X600" ")"))
Share this post
Link to post
muthu123
From help:
Actually My task is to return as a list.
Share this post
Link to post
gile
Hi,
You can't get something like this : (1.5X250X600) because 1.5X250X600 is not a valid symbol name.
Even '(1.5X250X600) should return (1)
This is due to the fact 1.5X250X600 contains a period (.).
Have a look at the Developer's Help > AutoLISP Developer's Guide W> Using the AutoLISP Language > AutoLISP Basics > AutoLISP Data Type > Symbols and Variables
Share this post
Link to post
SanganakSakha
Yes, Gile is right.
If acceptable, you could use , as a decimal separator instead of . and then have something like this:
(list '1,5X250X600)
It all depends on how you want to use this value - the larger picture.
Share this post
Link to post
VVA
could be so satisfied?
(read (strcat "(" [b][color="Red"]"\""[/color][/b] "1.5X250X600" [b][color="Red"]"\""[/color] [/b]")")) ;_return ([color="Red"]"[/color]1.5X250X600[color="Red"]"[/color])
Share this post
Link to post
BIGAL
I think this was answered in another post the problem is the ( ) the lisp sees these as part of the program not text. The simple way around is to use the "chr(x)" replace x with the keyboard character number from memory a=65 look up "ascii" function in lisp help,you only need like a 1 line lisp it gives the keyboard number.
(read (strcat chr(65) "1.5X250X600" chr(65)))
Share this post
Link to post
Lee Mac
The parenthesis make no difference - you can read these characters to interpret strings into valid LISP expressions.
The problem is as Gile describes in post #4
Share this post
Link to post
Michaels
I think it is better to use external file .txt and call them by openfile "r" finction
Regards
Michaels
Share this post
Link to post
Lee Mac
Regards
Michaels
This again would make no difference as read-line would return:
"(1.5X250X600)"
Which, when evaluated by 'read' would result in (1) as 1.5X250X600 is being interpreted as an integer as it is not a valid symbol name.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
