I have inheritted a 1985 digital theodolite which recordes position and height of each reading in the terain to be surveyd, which I then convert to an Autocad .dwg using an inhereted PC with Autocad14.
The result is a drawing with crosses to show the plan position of each reading and it's height above sea level.
From this information I would like to produce contour lines across the site.
Never visited a site like this before - please con some kind soul help me?
Thanks Ducboard .
PS is this what is meant by a thread??
AutoCAD14 by itself cannot produce contours.
Have a look in the folders in your inherited PC and see if you can find a programme called Soft Desk. This is a programme that can make contours.
As eldon mentioned, there's no way to create contours from survey data with vanilla Acad, other than manually drawing them.
This may help
http://www.sitetopo.com/
Unfortunately there is no Soft Desk programme At least I now know I cannot get contours in Acad14.
Thanks for your help.
Duckboard
From my previous question it appears aI canot produce contours in AutoCAD14 , but is it possible in DoubleCAD v2?
I appear to have no buddies or profile - as a newcomer I must admit to having difficulty in finding out what I should be doing on to rectify this!
Thanks
Ducboard
DoubleCAD is a lightweight CAD program, similar to Autocad LT. So no, DoubleCAD cannot generate contours.
If you want to do Civil work, generating contours and such, then you should be using a program like Civil3D.
I have merged your two threads together, since they are both regarding the same issue. Starting new threads, talking about issues discussed in a previous thread, just confuses everyone because no one knows what you're talking about. Just stay in one thread until your issue is resolved.
