tranquility Posted July 10, 2010 Posted July 10, 2010 hi guys! i would like to ask some help. see i've been task to set-up a drawing to another paper size at work but the thing is when i tried go over the "vport" in paper space it behaves as if it is in model space. i really appreciate if someone could help me on this. Quote
lpseifert Posted July 10, 2010 Posted July 10, 2010 Assuming you want to be in Paper space, not Model space... Try clicking on the Paper/Model button on the status bar or Dbl-click outside the viewport Quote
tranquility Posted July 11, 2010 Author Posted July 11, 2010 thanks for the reply Ipseifert but it doesn't solve my problem . see i already know that if I double click outside the viewport i will go to paper space. it's kinda like a viewport but i can't resize or delete it and when my cursor gets inside the box it changes to crosshairs. all i have is that the layer is named VPSTEP. i tried to surf the net for it and browse ebooks on autocad but to no avail. Quote
nukecad Posted July 12, 2010 Posted July 12, 2010 You have the viewport open. (This is why you cant select it to resize or delete and why the crosshairs appear only in the box not outside it). As lpseifert says click on the Paper/Model button to turn it on / off. If you cant see the button then type in PSPACE to close the open viewport (MSPACE to open a closed one). These work with the latest created viewport in the layout, for any others its easiest to use the double click method. Quote
