Tharwat Posted July 11, 2010 Posted July 11, 2010 Hi. Ncopy command is single selection type. How can I force it to get multiple entities as ssget for example ...? Thanks Tharwat Quote
Lee Mac Posted July 11, 2010 Posted July 11, 2010 ssget does not work well with nested selection - the closest is something like: (ssget "_:N") Then use ssnamex to retrieve the selected nested entities, but this is also quite troublesome. Quote
Tharwat Posted July 12, 2010 Author Posted July 12, 2010 Hello Yes you're right actually it is quite troublesome. I tried the following codes . (setq sset(ssget "_:N")) (ssnamex sset o) (command "_.ncopy" sset "" pause ) so I tried to reuse the command normally But that has caused the purge Message Box to appear after each selection set of of it !!!!!!!! So what has changed to the command since there were no odd actions had taken ???... as you can see..... Faithful Tharwat Quote
Lee Mac Posted July 12, 2010 Posted July 12, 2010 Your call to ssnamex is completely redundant, ssget "_:N" adds the parent entities to the SelectionSet, and the SubEntities can be found in the information returned by ssnamex. To get at these entities, perhaps use something like this: (vl-remove-if 'listp (mapcar 'cadr (ssnamex <SelSet>))) Quote
Tharwat Posted July 12, 2010 Author Posted July 12, 2010 It doesn't except the selection set that ... !!! But the question is ........ Why the PURGE msg box appear after calling NCOPY normally after each pick selection ? That was not before implementing the codes from the first time ....!! Best Regards Tharwat Quote
Lt Dan's legs Posted July 14, 2010 Posted July 14, 2010 ssget does not work well with nested selection - the closest is something like: (ssget "_:N") Then use ssnamex to retrieve the selected nested entities, but this is also quite troublesome. If I want to ssget "x" and ssget "_:n" together ? would that kind of selection even work? What I'm trying to do is select all of (2 . "blockname) even nested blockname and replace. I wrote the code to replace but wanted to know if the this selection will even work Quote
Lee Mac Posted July 14, 2010 Posted July 14, 2010 You cannot combine anything with "_X", - this mode doesn't look at the drawing entities themselves, but rather just scans the drawing database. To get at nested blocks you would need to look through the block definitions in the drawing for the required block and then modify the block definitions accordingly. Quote
