I cannot get this portion of the code to work. it does not even pop up with an error, it acts like it ignores it, and yes i do have my variables listed
(cond
   ((setq hide (getkword "\nHide Box? [Y/N] ? <Y>"))
  (if hide
   (command "-layer" "s" "Dim" "off" "Dim" "")
Try changing this:
To this:
(command "_.layer" "s" "Dim" "off" "Dim" "Y")
If that don't work, I would recommend submitting the reset of your lisp.
Just tweaking the code slighlty
Add Initget when using getkword to establish keywords for use by the next user-input function call
    (initget "Y N") ;Set the key words
   (setq hide (getkword "\nHide Box? [Y/N] ? <Y>")) 	;Get the input
   (if
    (= hide "Y") ;If the user has entered the required key "Y"
    (command "_.layer" "s" "Dim" "off" "Dim" "Y" "") ;Turn off the layer
Regards,
Jammie
Not sure if this applies, but when using the initget function, I usually specify a bit reference after the initget function syntax. I havnt got much experience using the initget function, so please correct me if I am wrong.
i.e.
(initget 1 "Y N") ; 1 = no null input
   (if
Hope this helps :)
  (initget "Yes No")
  (if (/= "No" (getkword "\nHide Box? [Yes/No] ? <Y>:   "))
      (command "_.LAYER" "s" "Dim" "_Off" "Dim" "_Y" ""))
By forcing the input with the (initget) bit flag, you negate the default "Y". So a nil response does not equal "No", so the test is T and the _.LAYER call will process.
I prefer the full word in an initget call. Even using the full Yes No, the nmenonics Y and N still work.
A couple of gottchas here.
- What if the layer DIM does not exist?
- What if the layer DIM is Frozen?
- If the sysvar EXPERT is set to 5, the prompt for turning off the current layer is bypassed.
A robust LAYER command can be a fairly lenghty call. My $0.02 -David
I get "invalid user keyword"
   (if
Regards,
Jammie
