harley558 Posted July 14, 2010 Share Posted July 14, 2010 I am running an analysis of a wheel. Is there a way of just using half the wheel (slicing it in half) so that it will simplify my analysis. The way it is now using the entire wheel it keeps crashing system. I know that I could possibly redraw the wheel and only revolve it 180 degrees instead of 360 but I really dont want to go through redrawing the structure. If there was a way of creating only half the wheel for analysis purposes after I have finished drawing the wheel any suggestions would be appreciated. Quote Link to comment Share on other sites More sharing options...
MarkFlayler Posted July 14, 2010 Share Posted July 14, 2010 Use the Split command to trim the solid and then when you are done suppress the Split you used for analysis. Quote Link to comment Share on other sites More sharing options...
harley558 Posted July 14, 2010 Author Share Posted July 14, 2010 This is an assembly, does the split command work with assemblies as well? Quote Link to comment Share on other sites More sharing options...
MarkFlayler Posted July 14, 2010 Share Posted July 14, 2010 Oh, well then no, it does not. You will have to put a cut in the assembly instead to cut through the parts and then suppress that when you don't need it.. Quote Link to comment Share on other sites More sharing options...
