Tipo166 Posted September 5, 2008 Posted September 5, 2008 Hello All, Let me give a brief outline: FuncA calls FuncB. FuncB generates an entity (a region) How do I "pass" or make usable the new entity (region) to FuncA. Currently trying to put the new entity in a selection set(???). Option Explicit Dim areaName As String Public Sub BuildingSQFT() Dim BuildingSQFT As AcadRegion areaName = "Building total area" 'Call function to generate area (region) required RegionGenerator 'Set BuildingSQFT = regObj End Sub Public Sub RegionGenerator() Dim pickPt As Variant Dim dblCoors() As Double Dim i As Long Dim oPoly As AcadLWPolyline Dim oEnt(0) As AcadEntity Dim regVar As Variant Dim lngResp As Long Dim regObj As AcadRegion Dim areaSelSet As AcadSelectionSet On Error Resume Next MsgBox (" Pick first point of " & areaName & " boundary region" _ & Chr(13) & "(Note: This should also be the last Point of the boundary)") pickPt = ThisDrawing.Utility.GetPoint(, vbCr & "First point: ") If Err = 0 Then ReDim dblCoors(1) dblCoors(i) = pickPt(0): dblCoors(i + 1) = pickPt(1) Do Until Err.Number <> 0 i = i + 2 pickPt = ThisDrawing.Utility.GetPoint(pickPt, vbCr & "Pick next point [or press Enter to stop]: ") ReDim Preserve dblCoors(UBound(dblCoors) + 2) dblCoors(i) = pickPt(0): dblCoors(i + 1) = pickPt(1) If oPoly Is Nothing Then Set oPoly = ThisDrawing.ModelSpace.AddLightWeightPolyline(dblCoors) Else oPoly.Coordinates = dblCoors End If Loop End If oPoly.Closed = True oPoly.Update Set oEnt(0) = oPoly regVar = ThisDrawing.ModelSpace.AddRegion(oEnt) Set regObj = regVar(0) oPoly.Delete Set areaSelSet = ThisDrawing.SelectionSets.Add("regObj") areaSelSet.AddItems regObj End Sub Quote
borgunit Posted September 5, 2008 Posted September 5, 2008 Basic concept.. Function GetAnEntity() as AnEntity DIm YourEntity "CREATE YOUR ENTITY" Set GetAnEntity = YourEntity End Function Quote
rocheey Posted September 5, 2008 Posted September 5, 2008 Im assuming your "FuncA" is a SUBROUTINE (not a Function) called "RegionGenerator", and your "FuncB" is a SUBROUTINE (not a Function) called "RegionGenerator". You want to have your Public Sub RegionGenerator () to be Public Function RegionGenerator ( ) as AcadRegion .... and, in the second Routine, where is says Set regObj = regVar(0) change it to Set RegionGenerator = regVar(0) ' yes, the *same name* you gave your function. And then erase all the stuff after that line, its not needed. Now, in your first routine, you just call it by just using a SET command: Set BuildingSQFT = RegionGenerator ' you can comment out the line that says ONLY "RegionGenerator", as well. '----------------------------------------------- To make your own function, you start out like you are making a SUB (except use the FUNCTION keyword) and then, after the brackets, put in the type of data it returns. For Instance, a Function that returns a String: Public Function MyStringFunction() as String MyStringFunction = "This Is a Test String" End Function .. Or a Function That returns a Line (code stolen from Help): Public Function MyStolenLineFunction() as AcadLine Dim lineObj As AcadLine Dim startPoint(0 To 2) As Double Dim endPoint(0 To 2) As Double ' Define the start and end points for the line startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0# endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0# ' Create the line in model space Set MyStolenLineFunction= ThisDrawing.ModelSpace.AddLine(startPoint, endPoint) End Function .. the trick here is, that somewhere in your function, you have to create the variable you want to return, using the name you described your function as. Then you can call it, like a regular VBA command. To call the String Function above, you could do something like this: MsgBox MyStringFunction To call the Line Function above, you'd need the SET command, first... Dim MyLine as AcadLine Set MyLine = MyStolenLineFunction ' Highlight your new line MyLine.Highlight True .. and whats with all these colors now? Quote
Tipo166 Posted September 5, 2008 Author Posted September 5, 2008 Im assuming your "FuncA" is a SUBROUTINE (not a Function) >>>>>>>>>>>>>> Uhhhmm.......yep! You want to have your Public Sub RegionGenerator () to be Public Function RegionGenerator ( ) as AcadRegion >>>>>>>>>>>>>>>>>>> Very helpful put in the type of data it returns. For Instance, a Function that returns a String: Public Function MyStringFunction() as String MyStringFunction = "This Is a Test String" End Function >>>>>>>>>>>>>>>>> clarifying (emberassingly so - but!) Thank you > works great and I understand. Colors > donno? copied and pasted straight from VBA IDE Quote
CmdrDuh Posted September 5, 2008 Posted September 5, 2008 you can try and add code tags around your code. I'm guessing the ESC codes are turning the text different colors Quote
CmdrDuh Posted September 5, 2008 Posted September 5, 2008 Hello All,Let me give a brief outline: FuncA calls FuncB. FuncB generates an entity (a region) How do I "pass" or make usable the new entity (region) to FuncA. Currently trying to put the new entity in a selection set(???). Option Explicit Dim areaName As String Public Sub BuildingSQFT() Dim BuildingSQFT As AcadRegion areaName = "Building total area" 'Call function to generate area (region) required RegionGenerator 'Set BuildingSQFT = regObj End Sub Public Sub RegionGenerator() Dim pickPt As Variant Dim dblCoors() As Double Dim i As Long Dim oPoly As AcadLWPolyline Dim oEnt(0) As AcadEntity Dim regVar As Variant Dim lngResp As Long Dim regObj As AcadRegion Dim areaSelSet As AcadSelectionSet On Error Resume Next MsgBox (" Pick first point of " & areaName & " boundary region" _ & Chr(13) & "(Note: This should also be the last Point of the boundary)") pickPt = ThisDrawing.Utility.GetPoint(, vbCr & "First point: ") If Err = 0 Then ReDim dblCoors(1) dblCoors(i) = pickPt(0): dblCoors(i + 1) = pickPt(1) Do Until Err.Number <> 0 i = i + 2 pickPt = ThisDrawing.Utility.GetPoint(pickPt, vbCr & "Pick next point [or press Enter to stop]: ") ReDim Preserve dblCoors(UBound(dblCoors) + 2) dblCoors(i) = pickPt(0): dblCoors(i + 1) = pickPt(1) If oPoly Is Nothing Then Set oPoly = ThisDrawing.ModelSpace.AddLightWeightPolyline(dblCoors) Else oPoly.Coordinates = dblCoors End If Loop End If oPoly.Closed = True oPoly.Update Set oEnt(0) = oPoly regVar = ThisDrawing.ModelSpace.AddRegion(oEnt) Set regObj = regVar(0) oPoly.Delete Set areaSelSet = ThisDrawing.SelectionSets.Add("regObj") areaSelSet.AddItems regObj End Sub I used the code tag instead of php tag Quote
