I have waisted enough time on this, I'm not too proud to ask...can someone direct me to the comand to "draw grid" (North/East) around the boder of my selected print area.
Thank you in advanced!
Simple way draw a line at known co-ords up page and across then offset or array at grid spacing. label as req'd.
There may be grid option in Civil3d but by the time I find it I would have done the grids . Get job finished then search help for next time.
That's what I actually ended up doing as time was definitely a factor...as a former Carlson Survey user I've found great improvements within Civil 3D, but thought what was a quick & easy command in Carlson would be just as streamlined if not better in Civil....time will tell, I'll post if I find the routine.
Thank you for your reply.
