Millsy29
Automatically Update Title block lisp HELP!
Millsy29
Hi everyone,
i have a lisp routine that i would like to alter to become more automated.
;* -------------------------- SUBROUTINE ------------------------------
(defun NEWSYSTEM ()
(cond
((= tagname "DRGNUM")(setq newdata drawingno))
((= tagname "CADFILE")(setq newdata cadfile))
((= tagname "REV")(setq newdata rev))
(T nil)
;* -------------------------- MAIN PROGRAM ------------------------------
(defun C:UPN (/ cadfile cadfilelen drawingno drawingrev drawingrevlen
rev field savefilename tagname newdata)
(setq cadfile (getvar "DWGNAME"))
(setq cadfilelen (strlen cadfile))
(setq drawingno (substr cadfile 1 (- cadfilelen 6)))
(setq drawingrev (substr cadfile 1 (- cadfilelen 4)))
(setq drawingrevlen (strlen drawingrev))
(setq rev (substr drawingrev drawingrevlen))
(setq field (entget (car (nentsel))))
(setq savefilename (cdr (assoc 1 field)))
(setq tagname (cdr (assoc 2 field)))
(NEWSYSTEM)
(setq field (subst (cons 1 newdata) (assoc 1 field) field))
(entmod field);modify database
(entupd (cdr (caddr field)));update entity without regen
this allows me to select the title block attributes and change accordingly to the file name. (not trying to teaching you to suck eggs)
Now what i want it to do as all the title block is to search for block "A0-Sheet" "A1-Sheet" "A3-Sheet" then find "cadfile" attribute and automatically change and so of for the drawing no. and rev.
Can anybody help me with this?
Millsy
Share this post
Link to post
Lee Mac
Haven't got anything to test it on...
(defun c:upn ( / ss )
 ;; © Lee Mac 2010
 (if (setq ss (ssget "_X" '((0 . "INSERT") (2 . "A#-Sheet") (66 . 1))))
     (lambda ( i / file l dwg rev e el )
       (setq file (getvar 'DWGNAME) l (strlen file))
       (setq dwg (substr file 1 (- l 6))
             rev (substr file (- l 4) 1))
       (while (setq e (ssname ss (setq i (1+ i))))
         (while
           (not
             (eq "SEQEND"
               (cdr
                 (assoc 2
                   (setq el
                     (entget
                       (setq e
                         (entnext e)
           (cond
               (eq "DRGNUM" (cdr (assoc 2 el)))
               (Update (SubstDXF 1 dwg el))
               (eq "CADFILE" (cdr (assoc 2 el)))
               (Update (SubstDXF 1 file el))
               (eq "REV" (cdr (assoc 2 el)))
               (Update (SubstDXF 1 rev el))
     -1
(defun SubstDXF ( code value elist )
 ;; © Lee Mac 2010
 (entmod
   (subst
     (cons code value) (assoc code elist) elist
(defun Update ( elist )
 ;; © Lee Mac 2010
 (entupd
   (cdr (assoc -1 elist))
Share this post
Link to post
Millsy29
it works the cad file changes and drawing no. changes but the rev comes out as - instead of A could this be its looking at the wrong part of the file name?
Example file name below:
302039-01M0201-003-A.dwg
Also this comes up at the end????
; error: An error has occurred inside the *error* functiontoo many arguments
Share this post
Link to post
Lee Mac
Yeah, I was about to ask for an example filename actually :)
Not sure about the *error* - that is something to do with an unlocalised error handler in another routine you are running as mine does not have an error handler.
Updated code.
Share this post
Link to post
Millsy29
BEAUITFUL PATRICK!!!!
:lol::lol::lol::lol::lol::lol::lol:
WORKS LIKE A CHARM!
thanks a million
Millsy
Share this post
Link to post
Lee Mac
Excellent - nice one :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
