I have the REvit 2010 Trial installed on my computer. I can't find the Imperial Library. Just the Metric.
My administrator is away this week (when I'm supposed to be working on this) so I can't install anything off the disk if it's on there.
  • 2 weeks later...
If you can only find the metric template you can try and install the Imperial Library from here. However you may require admin access to install it, in which case you'll have to work it out with your admin.
Or you could just join the rest of civilized world and work in metric. :P
  • 2 weeks later...
I AM GOING TO SNAP!!!! I downloaded the .cab files for Revit Structure. Now I am extracting them to a folder, and I have to hit Save for each one! There's a thousand frikkin' files!!! Is there no better way? Why wasn't this **** installed on the main disk?
now i have to organize 1300 files into subfolders.... awesome :reallymad:
Naturally you can install these when you install Revit, the link I gave you says so right at the top, so the blame rests squarely with the installer. PEBKAC errors are always the worst.
  • 4 weeks later...
yup, reinstalled, there's a little modify box upon installing where you pick the templates and default units.
