Autocad P&ID 2009
Hi guys,
I am using Autocad P&ID 2009 and draw a line diagram. I saved it and close the window. When I opened back the file, I wanted to delete some pipelines but it says "one was filtered out" and I won't be able to delete it. Is there any thing that i have missed on the settings or command? Please help me, thanks
I can't say about P&ID but the filtered out is often because you are trying to do something to an object on a locked or frozen layer. Check for that first.
hi dave,
I've checked it and the layers seems not locked. When I clicked the line and right clicked, there is an option "sub-object selection filter" which expands to:
no filter
vertex
edge face
solid history
by changing it, it doesn't change anything or i can't delete the line still.
  • 3 years later...
I had the same problem. I solved it by adding this drawing to the new progect in progect manager.
I'm so glad to solve this problem because I missed 1 week to find the solution!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:):):)
