Millsy29 Posted July 20, 2010 Posted July 20, 2010 i have created a button on my palette that plots a A0, a1 & a3 pdf's. how do i but this into a lisp routine that would allow me to plot A# (full size maybe as a wide card) to printer and pdf and a3 scale to fit to printer. -PLOT YES PDFCREATOR A0 LANDSCAPE NO EXTENTS 1=1 CENTER YES BLL-STD.stb YES YES NO NO NO NO YES I think i have a grasp of how to set it up to my own system but if someone could help with this, it would save me so much time.. Millsy Quote
Freerefill Posted July 20, 2010 Posted July 20, 2010 So far so good. You're on the right track, and that bit of code is pretty much all you need. Just put all that into a (command ...) function, then copy and paste for all the different plot settings and styles that you want. For example: (defun c:millsyplot( / ) (command "-PLOT" "YES" "PDFCREATOR" "A0" "LANDSCAPE" "NO" "EXTENTS" "1=1" "CENTER" "YES" "BLL-STD.stb" "YES" "YES" "NO" "NO" "NO" "NO" "YES") ) Quote
viviancarvalho Posted July 20, 2010 Posted July 20, 2010 i have created a button on my palette that plots a A0, a1 & a3 pdf's. how do i but this into a lisp routine that would allow me to plot A# (full size maybe as a wide card) to printer and pdf and a3 scale to fit to printer. -PLOT YES PDFCREATOR A0 LANDSCAPE NO EXTENTS 1=1 CENTER YES BLL-STD.stb YES YES NO NO NO NO YES I think i have a grasp of how to set it up to my own system but if someone could help with this, it would save me so much time.. Millsy Hi Millsy. What i do for printing is after i ve completed the dwg in model space, i do the complete page setup in paper space. when done just run a short lisp routine. Whenever you want to print the drawing, just open the dwg go to the layout you want to print, type pp & hit enter. ;start of code (defun c:pp() (princ "Type PP to run the command. \n Prints in one click,provided layout is set. \n Lisp by Vivian Carvalho") (setvar "cmdecho" 0) (command "plot" "n" "" "" "" "n" "n" "y")) ;end of code. Quote
Millsy29 Posted July 20, 2010 Author Posted July 20, 2010 i am having trouble with the output device (\\ukman04ma401\UK-MAN-04-01-KIP5000) lisp (defun c:plotsA0 nil (vl-load-com) (command "_.-plot" "yes" "" "PDFCREATOR" "A0" "m" "LANDSCAPE" "NO" "EXTENTS" "1=1" "CENTER" "YES" "BLL-STD.stb" "YES" "YES" "NO" "NO" "NO" "NO" "yes" ) (command "_.-plot" "yes" "" "\\ukman04ma401\UK-MAN-04-01-KIP5000" "A0_841x1189mm" "M" "LANDSCAPE" "NO" "EXTENTS" "1=1" "CENTER" "YES" "BLL-STD.stb" "YES" "YES" "NO" "NO" "NO" "NO" "yes" ) (command "_.-plot" "yes" "" "ukman04mz401\UK-RO-MAN-04-03 HPLJ5550 Design Printer" "A3" "M" "LANDSCAPE" "NO" "EXTENTS" "FIT" "CENTER" "YES" "BLL-STD.stb" "YES" "YES" "NO" "NO" "NO" "NO" "yes" ) (princ) ) AutoCAD text widow Command: _.-plot Detailed plot configuration? [Yes/No] : yes Enter a layout name or [?] : Enter an output device name or [?] \\ukman04ma401\UK-MAN-04-01-KIP5000>: > not found. when exicuted it comes out like this it seems to have a problem with the \'s does anyone know how to get around this? Millsy Quote
Freerefill Posted July 20, 2010 Posted July 20, 2010 This is a common occurrence. The backslash is a control code in LISP. You may have seen code that looks like this: (entsel "\nSelect entity: ") Well, that "backslash-n" means "insert a new line here". Without the backslash, it would just print the "n". TL;DR, what this means is that you can't just put a backslash in a string of text, otherwise when you run the code, it's expecting that backslash to indicate a control code. You can fix that by using the control code to create a special character. Ever want to put a quote in a text string? You do it like this: "something\"somethingelse". That "backslash-quote" says, "Don't stop the text string here, put a quotation mark in it!" By following the same logic, we can do this: "something\\somethingelse". Here's a way to see for yourself how it works. Copy and paste these bits of code into your command line on AutoCAD: (princ "Control code: \ ") (princ "Backslash: \\ ") (princ "Double-backslash: \\\\ ") In short, the answer to your question is: Replace \\ukman04ma401\UK-MAN-04-01-KIP5000 with \\\\ukman04ma401\\UK-MAN-04-01-KIP5000 Quote
Millsy29 Posted July 20, 2010 Author Posted July 20, 2010 thanks for that freerefill... all sorted :-) Quote
jcap91163 Posted July 31, 2010 Posted July 31, 2010 Thank you for this one, it helps me a lot, specially now that I'm trying to work a lisp that plot my drawings without the annoying window plot, I succeeded to plot a drawing to a pdf document and also plot an A1 sheet, but I've been experience troubles when trying to plot to a personalized sheet, always shows that the size sheet is not found, when trying to print, after the paper size, founds an error and cannot recognize the rest of the routine. If you would be so kind to help me with this, I'm writing the routine to see what's wrong: (defun c:toto nil (vl-load-com) (command "_.-plot" "yes" "" "HP DesignJet 500 24 by HP" "Pers. 5: 594 x 1150 mm." "m" "LANDSCAPE" "NO" "EXTENTS" "fit" "CENTER" "YES" "ba2.ctb" "no" "wireframe" "NO" "yes" "yes" ) (princ) ) many thanks in advance. Also, if I have elements outside the format, when I plot in "extents" mode this will plot everything in the model, is there any way to select "window" instead of "extents"? Quote
