Fire_col Posted July 26, 2010 Posted July 26, 2010 Now then, Been a while since I've been, not using AutoCAD much these days. However I am using it today. I've got an elipse drawn and I need to copy some lines around it, now I've tried using the Polar Array but it keeps arraying the item in a circle rather than the Elipse that I want. I can't think of any other way to do what I want so, can any of you guys help me out with a solution? Cheers Quote
ReMark Posted July 26, 2010 Posted July 26, 2010 When will the programmers come up with an elliptical array? Quote
busseynova Posted July 26, 2010 Posted July 26, 2010 I'd be interested too. I often have to space chair blocks around eliptical tables, the only way I know to do it is to use reflect with second point as a tanjent to the elipse, although the spacings are then completely arbitary. Quote
Fire_col Posted July 26, 2010 Author Posted July 26, 2010 Cheers Busseynova Mirror with tangent has worked quite well, but far too time consuming and as you said not as accurate as we'd like. ReMArk, I couldn't agree with you more, elliptical array would be ace, or even better array along path, we can extrude etc. along a path so why not array, it makes perfect sense to me! Ok rant over Quote
MSasu Posted July 26, 2010 Posted July 26, 2010 Doesn’t help you to use DIVIDE with a block on that ellipse? Regards, Quote
greg culjan Posted July 26, 2010 Posted July 26, 2010 if all you want is to divde the ellispe in "x" amount of equal distance, try using the divide command Quote
