rookie37 Posted July 27, 2010 Posted July 27, 2010 I make MANY simple drawings, take a screenshot, then paste in ms paint In order for my many screenshots to have the same scale, I put a handle point in the upper right and lower left corners. I zoom window and snap to these handle points. The program works great if the handle points are lines (snap endpoint or intersection) However, if the handle points are circles, (snap cen) nothing happens If I do the same thing without the macro, snap cen works great I'm almost certain circles for handle points worked before. Now nothing (defun c:zw () (setq pt1 (getpoint "\nSelect First Window Point: ")) (setq pt1 (osnap pt1 "_endp")) (setq pt2 (getpoint "\nSelect Second Window Point: ")) (setq pt2 (osnap pt2 "_endp")) (command "zoom" "w" pt1 pt2 ) ; end zoom (princ) ) ; end programIts not ideal though. Quote
MSasu Posted July 27, 2010 Posted July 27, 2010 Is not a bug, it is because circles don’t have EndPoint Osnap – you should modify the filter to accept CenterPoint too: (osnap pt1 "_end[color=red],_cen[/color]") Regards, Quote
Tharwat Posted July 27, 2010 Posted July 27, 2010 Try this one ....... it is dedicated to you. (defun c:zw (/ old pt1 pt2) (setq old (getvar 'osmode)) (setvar 'osmode 1) (setq pt1 (getpoint "\nSelect First Window Point: ")) (setq pt2 (getpoint "\nSelect Second Window Point: ")) (command "_.zoom" "_w" pt1 pt2 ) (setvar 'osmode old) (princ) ) Tharwat Quote
