I have a survey that is all on the same layer but i would like to delete the levels. Is there anyway i can select the whole drawing, then just select the text and hit the delete button on my key board? Thanks
Ouch. I do sympathise
Have you tried the Filter command to select text only? But be careful. Levels may not be the only text in the drawing
  • 3 weeks later...
QSELECT or try the SELECT SIMILAR command (use right button on mouse).
The select similar command dissapeared from Autocad in the 2007 version, but it's back in 2011.
http:/cad-no.blogspot.com
