Changing properties of this lisp, please help...
HI,
Can someone please help, I've been trying to change the properties of a usefull lisp i use.
This lisp gives me a level value each time i pick a point but I would like to change the linetype & point marker.
Has anyone any ideas how to change this?
Thanks in advance.
Nelie.
Lisp below.
(defun c:txm()
(terpri)
;; Perform math on text numbers in-place, by Carl B., coded March 2000
(setvar "cmdecho" 0)
;; select lines to annotate
(setq mfactor 1 afactor 0 input nil)
(initget "M A")
(setq input (getkword "\nMultiply<M> or Add<A>?: "))
(cond
((= input "M") (initget 1)
(setq mfactor (getreal "\nMult Factor: ")))
((= input "A") (initget 1)
(setq afactor (getreal "\nAdd Amount: ")))
(T nil)
) ; cond
(initget 1)
(setq precis (getint "\nPlaces after decimal: "))
(setq units (getstring T "\nEnter units to append: "))
(princ "\nSelect text to revise: ")
(setq textset nil)
(while (not textset) (setq textset (ssget '((0 . "*TEXT")))))
(setq numitems (sslength textset))
;; loop to isolate text & change text
(setq itemno 0)
(repeat numitems
(setq entname (ssname textset itemno))
;;(setq enttype (cdr (assoc 0 (entget entname))))
(setq oldtxt_pr (assoc 1 (entget entname)))
(setq oldtxt (cdr oldtxt_pr))
(setq oldtext# (atof oldtxt))
(setq newtext# (+ (* oldtext# mfactor) afactor))
(setq newtxt (strcat (rtos newtext# 2 precis) units))
(setq newtxt_pr (cons 1 newtxt))
(setq entstuff (entget entname))
(setq entstuff (subst newtxt_pr oldtxt_pr entstuff))
(entmod entstuff)
(setq itemno (1+ itemno))
) ; repeat
) ; the end
(princ "Do math on text Start with \"TXM\"")
This lisp gives me a level value each time i pick a point...
You are sure that this lisp works so?
It works with my machine and 2008 but i just need to change the text style and point marker.
Are you able to help?
Regards
I am capable to help if you specify your requirements. ...i just need to change the text style and point marker. - here is not enough information to make something.
Nellie,
If I understand it correctly, (and correct me if I am wrong), but the LISP that you are using is a program that will perform some math on text that contains numbers.
When you say
Do you mean change the text style?
Hi Guys,
Sorry for not giving the right info guys.
This lisp is curently creating the level (text style) as Standard-Courier New at a height of 0.2 but i would like it at Standard-Simple at a height of 0.18.
I would also like the arrow which is currently being created to be replaced by a cross (+) with a 0.18 size.
Thanks again in advance.
Nellie
This lisp is curently creating the level...
It some other lisp not C:TXM. Can you to publish that lisp or screenshort picture with your level markers?
...but i would like it at Standard-Simple at a height of 0.18
Do you mean Simplex.shx font?
Try this. It creates block with attribute LEVEL and cross marker and adds "Simplex" style automaytically.
(defun c:lemar(/ sCol bCol nStl nBlk
          cBlk nAtr ln1 ln2 cAtr)
(vl-load-com)
(setq aDoc(vla-get-ActiveDocument
      (vlax-get-acad-object))
     sCol(vla-get-TextStyles aDoc)
     bCol(vla-get-Blocks aDoc)
     ); end setq
 (if(vl-catch-all-error-p(vl-catch-all-apply 'vla-Item
 (list sCol "Simplex")))
      (setq nStl(vla-Add sCol "Simplex"))
      (vla-put-FontFile nStl "simplex.shx")
     ); end progn
   ); end if
 (list bCol "Level Marker")))
   (setq nBlk(vla-Add bCol
	       (vlax-3D-point '(0 0 0))
	       "Level Marker"))
   (setq nAtr(vla-AddAttribute nBlk 0.18 acAttributeModePreset
                     "" (vlax-3D-point '(0 0 0)) "LEVEL" "X"))
   (vla-put-Alignment nAtr acAlignmentBottomCenter)
   (vla-put-StyleName nAtr "Simplex")
   (vla-put-TextAlignmentPoint nAtr
     (vlax-3D-point '(0.0 0.1 0.0)))
   (setq ln1(vla-AddLine nBlk(vlax-3D-Point '(-0.09 0.0 0.0))
                    (vlax-3D-Point '(0.09 0.0 0.0)))
         ln2(vla-AddLine nBlk(vlax-3D-Point '(0.0 -0.09 0.0))
                    (vlax-3D-Point '(0.0 0.09 0.0))))
   (mapcar 'vla-put-Layer '(nAtr ln1 ln2) '("0" "0" "0"))
    ); end progn
   ); end if
 (princ "\nPlace level marker or Right Click to Quit> ")
 (while(setq cPt(getpoint))
   (setq cBlk(vla-InsertBlock(vla-get-ModelSpace aDoc)
	(vlax-3D-Point cPt)"Level Marker"
	 1.0 1.0 1.0 0.0)
  cAtr(car(vlax-safearray->list
       (vlax-variant-value(vla-GetAttributes cBlk)))))
   (vla-put-TextString cAtr(rtos(cadr cPt)2 2))
   ); end while
 ); end of c:lemar
