hosannabizarre Posted July 29, 2010 Posted July 29, 2010 It is not an uncommon problem for AutoCAD users to find unselectable or phantom elements in their drawings. An effective remedy to this issue are the following steps: 1. select all 2. erase 3. "oops" ...then the unselectable element become selectable, and you get on with your day. We have received a set of drawings where these phantom elements crop up quite regularly. I want to make a lisp, and then a button, to run the commands listed above. I can't quite get it to work right. This is what I've done: (defun c:fixphantoms () (command "_ai_selall") (command "_.erase") (command "oops") ) (princ) ) If I run this is leaves me at a position where I am prompted to select objects (which I don't want). If I go: Cntrl+A, then press delete, then type "oops", it's all over and my phantoms are fixed. Can someone please advise how I can change the lisp code so that the three commands get executed and I'm not at a prompt to 'select objects'. Thanks Quote
CALCAD Posted July 29, 2010 Posted July 29, 2010 Try writing the command so : (command "_ai_selall" "") Quote
hosannabizarre Posted July 29, 2010 Author Posted July 29, 2010 Thanks CALCAD Gave that a try, but I'm still having the same issue where, after running "fixphantoms", I'm prompted to select objects. Cheers for the suggestion Quote
CALCAD Posted July 29, 2010 Posted July 29, 2010 hosannabizarre, Sorry, I thought that would work, but alas. I don't have the ai_selall command in my Bricscad or Intellicad, so I don't know the proper syntax. You might try Selgrips as in : (command "._selgrips" "all" ""), which may accomplish the same thing. Just a thought. Quote
