When i zoom to extents or all, the view zooms out and my drawing is very small centered in the bottom of the screen. I have tried to find any delete any stray objects that may be somewhere else in the view, but without success. :reallymad:
Any ideas?
Check that all your layers are on and thawed. Also, check to see if you have any Images, or Xref's in your drawing, but are loaded.
Opened and thawed all layers. There is one EXCEL reference that is loaded.
Still having same problem.
Look for null text entities also.
Zoom to the area of your drawing, do an ERASE>ALL, then REMOVE your actual drawing entities from the selection set.
Are there any objects remaining in the selection set?
Check the 0,0 point of any blocks and Xreference's..
