Hello
I normally use right click as end last command etc, no shortcut menu.
However i have found I want to use ctrl+right click to access the menu, currently by default if is osnap menu. I know how to change it but whats the command/macro to bring up the shortcut menu?
Thanks
You can go to OPTIONS dialog box & you will find the right click customization in under the USER PREFERENCES tab.
Thanks, not quite what im after. I want to bind the shorcut menu to "ctrl + right click" i know how to change it within the cui just wasnt sure what macro/command i should put.
It sounds like you want to customize a shortcut key. Is that right?
The procedure for doing so is covered in your Customization Guide on pages 330 to 332. That's Chapter 4 - User Interface Customization.
moz-screenshot.pngI think people are getting confused. I want to change right click button which brings up the shortcut menu. To being shift+right click. The attached picture i will have to change the macro to something. But not sure what.
