Adding additional text to Dimension Text Override
I have a piping isometric that is not drawn to scale that needs to have the imperial dimensions added. The drawing is currently dimensioned in metric with all dimensions having a text override. I am looking for a way to take the text that is in the override and adding the imperial equivalent ie 300 changed to 300 [11.811]. Is this possible with a Lisp? Will the numbers in the text override be able to be converted?
  • Replies 25
  • RoguePiper
    8
  • Lee Mac
    7
  • Tharwat
    7
  • Lt Dan's legs
    2
Posted Images
Perhaps something like this?
(defun c:ImpDim ( / ss )
 ;; © Lee Mac 2010
 (if (setq ss (ssget "_:L" '((0 . "DIMENSION"))))
     (lambda ( i / e s n )
       (while (setq e (ssname ss (setq i (1+ i))))
         (if (and (setq s (cdr (assoc 1 (entget e)))) (setq n (distof s)))
           (entupd
             (cdr
               (assoc -1
                 (entmod
                   (subst (cons 1 (strcat s " [" (rtos n 3) "]")) (assoc 1 (entget e))
                     (entget e)
     -1
It assumes that the original Dimension Override is purely a number however.
Thanks for info. I will look into both. Lee Mac, I will give yours a try, the original are all numbers.
Have you tried it mr Rogue?
For me, it is not working although the racism is very clear in that reply !!!!!
For me, it is not working although the racism is very clear in this reply !!!!!
WTH? Racism? Did I miss something? Grow up Tharwat.
Racism? hmmmmm , a little difficult to be racist when I have no idea what race you or anyone else is.
Lee Mac posted a specific script, your post was a link to a very informative post that seems more like a tutorial. I have not had a a chance to try it.
can you see the difference between this thread and the following link thread ?
http://www.cadtutor.net/forum/showthread.php?50963-Update-the-contents-of-a-Dimension-Style
And there are lots of things to get.....
That is not racism, and it clearly reflects how immature you are to suggest such an absurd claim. Do you really expect me to answer every thread on this forum, and hold it against me if I don't?
In any case, some of us aren't too tolerant of the code plagiarism you have demonstrated in the past.
Since that you consider your self a mature, your answer should be more polite.
I do not expect any thing from you since is that is one of your answers.
And I am not waiting for your tolerance at all, beside that, I am very proud of
what I am doing and saying and so on......
And if you consider your self is the father of all , its up to you. And of course
me is excluded.
your replies claim what you think of ......
I did not consider my response in any way rude - I stated my opinion of your previous response in a clear and concise manner.
Your previous response suggested that I displayed 'racism' (I think you need to look that word up) towards you since I did not reply to your thread.
If that is your view, then we quite clearly disagree on what we consider to be good coding etiquette. But I would prefer if you didn't throw a tantrum should I decide not to answer your future threads.
I have told you before that I do not care if you reply or not. Because you do not give something to be learned by any, you only show your muscles infront
of people. And that's not what I am looking for ....
Please not do reply to my threads at all, since that you will show your prouds againt others, which is completely I hate this kind of habit.
When you become more modest, you would be welcomed in that time only.
Then why shout 'racism' ?
of people When you become more modest, you would be welcomed in that time only.
Oh right, I forgot I am only allowed to post code that Tharwat is able to understand. Complexity of code is a matter of opinion: I cannot see how you can reprimand my lack of modesty for posting code just because you feel it is too complex.
to tharwat313,
I'm not trying to be mean or a d*ck but I've come here to learn, not to argue
www.cadtutor.net homepage
"CADTutor delivers the best free tutorials and articles for AutoCAD, 3ds Max and associated applications along with a friendly AutoCAD forum and an AutoCAD FAQ. If you need to learn AutoCAD, you're in the right place."
The way I see it, if you cannot post without getting into an arguement or offend others than maybe this site isn't for you. If you dissagree, just ignore this post.
I like to keep stress out of my life as much as possible and you'll be much happier if you do the same.
Because it is the truth. As I told you a long time a go that you do not give a complete help unless someone initiate, And in that time
muscles would be shown clearly.
You still can not get my point well , And that's for sure due to your up rised nose against others. or a toss.
to tharwat313' date='[/b']
You must be reading what I have inside. So your advise must be given to someone else.
I thank you for your kind reply.
I answer the threads that I want to answer - I don't know what you are talking about. 'Muscles'? I'm not going to post 'simple' code just so that Tharwat can understand it, believe it or not, there are those who benefit from more challenging code.
Again, I don't know how you draw these conclusions but it is obvious that you are only here to cause trouble. If you don't like the complexity of my code I suggest you ignore it.
I think this is getting out of hand...
Really- the combative nature and the allegations of racism. I would suggest that everybody ignore his threads/posts and maybe he'll go away.
Edited by lpseifert
Lee Mac, that is very close to what I was looking for. Thanks you very much. Lets see if we can get this back on track. I just need to tweak it a little bit to make it perfect.
Right now it is taking the text as inches and just converting to feet inches, my dimensions are all in mm and need to be converted to decimal inches, to 3 decimal places.
And I need to have the imperial dimension appear below the dimension line, so I just need to add a \X into the text string, but not quite sure where that would go.
I changed the code to convert the dimension into inches now. I changed to this
(setq n (/ (distof s) 25.4)))
When I try and get the text to display below the dimension line by adding the \X to the string, it drops the \ and only adds the X. Any suggestions?
Full modified code
 ;; © Lee Mac 2010
         (if (and (setq s (cdr (assoc 1 (entget e)))) (setq n (/ (distof s) 25.4)))
           (entupd
             (cdr
               (assoc -1
                 (entmod
           (subst (cons 1 (strcat s " [" (rtos n 2 3) "]")) (assoc 1 (entget e))
                     (entget e)
     -1
