thegodplato Posted August 3, 2010 Posted August 3, 2010 As the title says, how do you get different layers showing in multiple viewports? I need to show 2 plans of a building layout on the same drawing but they need to have different layers on. When I switch a layer on/off or freeze, the layer goes from both viewports. I haven't done this before so any help would be appreciated. Quote
Tiger Posted August 3, 2010 Posted August 3, 2010 While the viewport is active, open the Layer Manager and scroll over to the left. You will see a column called VP Freeze - use that to freeze layers in a single Viewport. Quote
