Dont have the time to look it up. How can I get different layers have different fading in different layouts? Is that even possible?
Thanks, L
Assuming you're using color based plotting...
In the .ctb file, assign different Screening values for different colors
You can use layer overrides for the layers' color for the viewports in the different layouts.
I'm not sure if i got it. I want the object I drew in the model to show different things in layouts. Ex. Layout 1 I want the electrical wiring to be bolder than the background, in Layout 2 I want something else to be bolder. If I do the color screening thing won't it be the same for all my layouts? Oh and I'm using monochrome plotting.
Look in Help for Viewports > overriding layer properties
