Centralised ModelSpace Views (VBA)..
Hi,
How do I get the current modelspace view to be centralised on screen using VBA?
I have a program that lists all layouts or modelspace views and when the user clicks on them in the listbox, autocad displays that layout (obviously makes that layout active) or displays that view, but with the view, it is always left-aligned on screen, but i would prefer it to be central. Is there a way to do this?
yes, use the zoom centre option
grab the minimum and maximum coordinates, work out the view centre and use that
Hi,
Which object has that as a property? I have this sample code but can't see which object would have the zoom centre option..
Dim ViewsX As AcadViews
Dim ViewZ As AcadView
Dim viewportObj As AcadViewport
Set ViewZ = ThisDrawing.Views.Item(ListBox1.Text)
Set viewportObj = ThisDrawing.ActiveViewport
viewportObj.SetView ViewZ
ThisDrawing.ActiveViewport = viewportObj
it's not an object, it's a method - ZoomCenter, ZoomExtents, ZoomScaled etc
straight out of the Help file....
' ZoomCenter
   MsgBox "Perform a ZoomCenter using:" & vbCrLf & _
          "Center 3, 3, 0" & vbCrLf & _
          "Magnification: 10", , "ZoomWindow Example"
   Dim zcenter(0 To 2) As Double
   Dim magnification As Double
   zcenter(0) = 3: zcenter(1) = 3: zcenter(2) = 0
   magnification = 10
   zoomcenter zcenter, magnification
