JPG reference unknown file path
Eric 12
:x
I have attached a .JPG to the drawing using Image manager in 2004. I need to email this file to different jobsites and when they get the drawing it is referencing my desktop. How do I save the image in the drawing and not reference my computer? This is not a great callamity I just hate it when I can't figure simple things out.
Thanks in advance
:x
Thanks in advance
Well this was an old problem where if you had any xrefs or image attachments they would need re-attaching when sent via email.
I'm not sure about 2004 version but in newer versions you have a few options, you can use the etransmit command to package all the files up together. You can also use a relative file path instead of full path when inserting.
EDIT: Also you may be able to attach it as an ole object.
