how can we call dll created in .Net from Vlisp?
Dear friends,
How can we call the .NET dll from Vlisp?
Regards,
Muthu.
After the DLL is loaded into AutoCAD ;
call methods attributed as 'CommandMethod' the same you call AutoCAD commands,
call methods attributed as 'LispFunction' the same as you call ordinary Lisp Functions
Can you explain briefly with some examples?
Regards,
Mtuhu
First Load the DLL file
(defun-q S::STARTUP ( )
 (command
   "_NETLOAD" "C:\\Test\\Test-01.dll")
 (command
   "_NETLOAD" "C:\\Test\\Test-02.dll")
Then call the function ordinary same as lisp function
For example
(function-01)
