sinnerboy Posted August 12, 2010 Posted August 12, 2010 I am using LT 2009 . I have placed a block with an attribute to number-tag windows in elevation . Some windows have been removed - and I have to renumber a lot of block tags . Is there a macro which would allow me to select the block tag and edit the number i.e. - click on the block and it adjusts the text-number by -2 ( W27 becomes W25 ) . Quote
BIGAL Posted August 13, 2010 Posted August 13, 2010 There are a number of USER variables that can be stored in the drawing USERI1 is an integer USER1 is a real you may perhaps with diesel be able to set a number then recall the user variable and add 1 and put that value into the attribute, within a macro. "setvar useri1 -2" Don't use LT sorry Quote
sinnerboy Posted August 17, 2010 Author Posted August 17, 2010 Thanks Bigal - actually I do have access also to a (full) AutoCAD 2009 workstation . So is there a lisp which would allow me to select the block tag and edit the number i.e. - click on the block and it adjusts a user determined text-number . Example -2 so W27 becomes W25 . Quote
