Jeff25 Posted August 13, 2010 Posted August 13, 2010 I want to create a custom line. Is it possible to draw one in a dwg file save, and load it into linetypes in the file you want to input it in? Quote
rkmcswain Posted August 13, 2010 Posted August 13, 2010 You can use DesignCenter to copy linetypes from one drawing to another. If you want to export a linetype in a drawing to a .LIN file, use TO-LIN.LSP found at http://www.turvill.com/t2/free_stuff/index.htm If you don't know what to do with a lisp file, see http://www.cadtutor.net/faq/questions/28/How+do+I+use+an+AutoLISP+routine%3F Quote
