ManAtWork Posted August 13, 2010 Posted August 13, 2010 Hello once again i cant open a file, cause i have to enter all the adress file in the line comand box, what is the command to put it back to normal ( open a file with the "mouse"). Another thing... when i import a survey TXT point file with Coordinates, the Autocad civil 3D ( Survey) does enter the points with the same desing as it should be in the field, but with wrong( modified) coordinates and levels than it should. what a hell happens?!!! if the txt file its super correct? i cant enter that same file in the land 2009 desktop but not on the civil why? can someone help me in this problem please? Quote
Squirltech Posted October 13, 2010 Posted October 13, 2010 The command to get back your dialog box is: *filedia* then enter the value of *1* Be sure to check your point settings, your point management and your label settings. If your edit label styles or label settings are pointing somewhere else, this will throw off your point settings that you require. Hope this helps. Quote
