TuFoFi Posted August 15, 2010 Posted August 15, 2010 Hello, This will be simple for one of the regular pros. I have this one line of code. setq ss (ssget '((0 . "INSERT")(66 . 1))) Works perfect for creating a selection set of blocks with attributes. I want it to include all NESTED blocks with attributes as well. I thought the ":V" parameter would work, but I am struggling with the syntax. It may even require a recursive routine. Your expertise would really help. Thank you. Quote
Tharwat Posted August 15, 2010 Posted August 15, 2010 Code: (sssetfirst nil(ssget "_x" '((0 . "INSERT")(66 . 1)))) Try the following code to get the DXf for Block Attributes and upload them here to check them out . Code: (setq ss (car(entget(entsel)))) Regards, Tharwat Quote
Tharwat Posted August 15, 2010 Posted August 15, 2010 Check this link to see the similarity of codes . http://www.cadtutor.net/forum/showthread.php?48702-Find-nested-blocks&highlight=select+nested+block Regards, Tharwat Quote
Lee Mac Posted August 16, 2010 Posted August 16, 2010 Not as simple as you may think, - actually very difficult. ssget has no robust functionality for selecting nested items, there are such modes as ":N" but these are highly temperamental indeed. If I remember Tim Wiley attempted to write an alternative to ssget for nested items, but the selection process would be hundreds of lines of code in itself... Lee Quote
