get properties of an object(s) to populate a form
Hello All!
For ref, recent thread - "calling a function to return an entity"
I wrote a couple small subs to generate a region. What I am after is the area of that region (a property of region objects) and passing it to a user form.
First solution was trying to use SelectionSets...grrrrrr.....this is my second solution path (SEEMS less harder - humor):
Currently creating a dictionary of the areas of the regions then passing those values into my form. I have reviewed several examples and believe my code is reasonably accurate (ref "AddObject" method & example -Acad Developers Help). However I can not get the area(s) to populate in the dictionary? Watch shows the dictionary creation as checking out. I am assuming once a dictionary (and its contents) is created it is a perminent part of the DWG i.e. accessable the next time the DWG is opened?
1) Anyone familiar with this error?
"AcRxClassName entry is not in the system registry"?
2) does AddObject apply only to ObjectARX objects??
Dictionary creation and AddOject statements:
'Check to see if this dictionary exists if it does not - add it
 Dim FlrSpcRegsDict As AcadDictionary
 On Error Resume Next
 Set FlrSpcRegsDict = ThisDrawing.Dictionaries.Item("Floor_Space_Regions_Dictionary")
 If Err.Number <> 0 Then
 Err.Clear
 Set FlrSpcRegsDict = ThisDrawing.Dictionaries.Add("Floor_Space_Regions_Dictionary")
 End If
'Uniquely ID this regions area and put in dictionary
   Dim keyName As String
   Dim ObjectName As String
   keyName = "BuildingSQFTreg"
   className = "SQFTregion"
   'Add BuildingSQFT to the dictionary in the drawing
   BuildingSQFTarea = FlrSpcRegsDict.AddObject(keyName, className) << not working!!! BuildingSQFTarea also checks out as correct with a watch>>
The dictionary is created but never has any objects in it (count = 0) so my BuildingSQFTarea is not being stored(?).
Label control object of form:
Private Sub Total_SqFt_Number_Click()
 Dim BuildingSQFTarea As Double
 'Find the object
   Dim tempObj As Double
   Set tempObj = FlrSpcRegsDict.GetObject(BuildingSQFTarea)
Total_SqFt_Number.Caption = tempObj
End Sub
