ruize77 Posted August 18, 2010 Posted August 18, 2010 Hi... i got an issue... i use metric system in both autocad and sketchup... For some reason if i export a file from cad to sketchup, they don't match... for example I exported a 3d model of a kitchen with walls of 2.70m high... but when i opened it up in sketchup they were only .80m tall why would this happen? thank you! Quote
designerstuart Posted August 18, 2010 Posted August 18, 2010 check when you import it that units - not the standard 'in program' units but IMPORT units - are correct. it's annoying to find, think it's when you select the file to import there are some extra options you can change - that happened to me anyway! Quote
