jbird68 Posted August 20, 2010 Author Posted August 20, 2010 Here's a trick I use: view the model in isometric: Command: vpoint Rotate/ now set the UCS to the current view: Command: ucs Origin/ZAxis/3point/OBject/View/X/Y/Z/Prev/Restore/Save/Del/?/: v Select all and copy to your clipboard. Start a new drawing and paste the contents of the clipboard, explode and flatten (or solprof/soldraw/soldraw) as ReMark states Patrick, Thanks for this tip. It does what I was looking for. I guess if I have to create an assembly I will have to spend some time modeling and then use the vpoint command. At lease that is quicker than trying to do 2D isometrics. Quote
jbird68 Posted August 23, 2010 Author Posted August 23, 2010 okay, I try this again and now I don't get an option for "View" after I use the ucs command. I get these choices: [New/Move/orthoGraphic/Prev/Restore/Save/Del/Apply/?/World] Quote
jbird68 Posted September 24, 2010 Author Posted September 24, 2010 I can add the views to my 2D drawing but they are not flat. If I 3D Orbit(rotate) my drawing the original part of the drawing is flat, but my addition is not. It protrudes through the flat drawing, but when I set my view to "Top View" it looks fine. I can live with it as-is. But I am just curious as to how I should make it all flat. Quote
