nocturne00 Posted August 20, 2010 Posted August 20, 2010 Hi all. i'm not sure what I did, or if i really did anything to set this, im not even sure if its a veiwport issue or graphics issue, but whenever I zoom, a sort of invisible "cutting plane" does a section on where the picture plane intersects my objects. the image shown is not a section, its an enclosed building envelope, but whenever I zoom in, the picture plane cuts thru it. Originally this was not like this, I mean, when I zoom in, the picture Plane penetrates the walls. I hope my explanation is clear. Quote
CAD Library Posted August 20, 2010 Posted August 20, 2010 I think its a graphics issue.. maybe its your videocard? Quote
nocturne00 Posted August 20, 2010 Author Posted August 20, 2010 but it just surfaced now, thats why im doubting its a hardware issue. anyway, i reset to a new scene and imported the models again, now its ok. but I hope someone can give a quick tip about why this happens for all others who encouter this. Quote
Cad64 Posted August 20, 2010 Posted August 20, 2010 I'm not really sure what I'm looking at? Can you post some more screenshots? Quote
nocturne00 Posted August 27, 2010 Author Posted August 27, 2010 Hi cad64, really really sorry for the late reply,,, my head is spinning at work here's some more screen shots of my problem. the first image happens when I zoom in, the second image is the whole one. it sort of slices the object at the view plane. its a bit irritating coz i need to zoom in for detailing but it cuts the object too early during zooming in. I hope you've encountered -- (and possibly solved) this issue before many many thanks Quote
Cad64 Posted August 27, 2010 Posted August 27, 2010 Ok, it looks like your "Field of View" needs to be adjusted. The default setting is 45, so try setting it at 20 and see if that helps. Right click on the "Field of View" button to open the "Viewport Configuration" dialog. Quote
nocturne00 Posted August 27, 2010 Author Posted August 27, 2010 Cad64, you're AWSOME!!! thanks a zillion! solved the problem completely. Quote
