How do I bend a 3d cylinder
FordForever5305913
i am trying to make a exaust pipe for a semi i am making in autocad 2006 and the pipe bends at the top. so i was wondering how can i bend a 3d cylinder/pipe?
Thanks
  • Replies 38
  • ReMark
    11
  • belexes
    6
  • ASMI
    3
  • darkman257
    3
Draw the centerline of the exhaust pipe, using a polyline, then draw and extrude a circle along this "path" corresponding to the O.D. of the pipe.
  • 2 weeks later...
Hi,
I am a bit of a novice when it comes to design but I can make way around AutoCAD 2006. How did you go about creating your exhaust pipe based on poly line?
Regards
Sean
Try this two LISPs.
(defun c:xpipe(/ ACTDOC ACTLAY ACTSP BASELINE
         BASESET CIRENT DICOUNT DIVDID
         EXCIR LAYST OBJTYPE OLDDIA
         OLDECHO STARTPT XORD YORD
         ZORD *ERROR*)
 (vl-load-com)
 (defun *error* (msg)
   (vla-put-Lock actLay laySt)
   (setvar "CMDECHO" oldEcho)
   (vla-EndUndoMark actDoc)
   ); end of *error*
 (if(not pipe:exDia)(setq pipe:exDia 40.0))
 (setq actDoc
   (vla-get-ActiveDocument
     (vlax-get-Acad-object))
  actLay(vla-get-ActiveLayer actDoc)
       oldDia pipe:exDia
       oldEcho(getvar "CMDECHO")
  ); end setq
 (vla-StartUndoMark actDoc)
 (setvar "CMDECHO" 0)
 (if(= 0(vla-get-ActiveSpace actDoc))
   (setq actSp(vla-get-PaperSpace actDoc))
   (setq actSp(vla-get-ModelSpace actDoc))
   ); end if
 (setq laySt(vla-get-Lock actLay))
 (vla-put-Lock actLay :vlax-false)
 (setq pipe:exDia
   (getreal
     (strcat
       "\nSpecify pipe diameter <"(rtos pipe:exDia)">: ")))
 (if(null pipe:exDia)(setq pipe:exDia oldDia))
 (initget "Yes No")
  (setq delFlag
         (getkword "\nDelete extrude path(s)? [Yes/No] <No>: "))
   (if(null delFlag)(setq delFlag "No"))
 (princ "\n<<< Select objects to extrude and press Enter >>>")
 (if
   (setq baseSet
     (ssget '((-4 . "<OR")(0 . "*LINE")(0 . "CIRCLE")
          (0 . "ARC")(0 . "ELLIPSE")(-4 . "OR>")
          (-4 . "<NOT")(-4 . "<OR")(0 . "SPLINE")
               (0 . "MLINE")(-4 . "OR>")(-4 . "NOT>"))))
     (setq baseSet(vl-remove-if 'listp
                             (mapcar
           'cadr
           (ssnamex baseSet))))
     (foreach pathEnt baseSet
     (setq baseLine
       (vlax-ename->vla-object pathEnt)
      objType(vla-get-ObjectName baseLine)
           startPt(vlax-curve-getStartPoint baseLine)
           3dPos
       (vlax-curve-getFirstDeriv baseLine
         (vlax-curve-getParamAtPoint baseLine startPt))
          diCount(strlen
           (itoa
        (apply 'max
         (mapcar 'abs
          (mapcar 'fix startPt)))))
      divDid "1"
      ); end setq
     (repeat diCount
  (setq divDid(strcat divDid "0"))
  ); end repeat
     (setq divDid(atoi divDid))
     (if(/= 0.0(car 3dPos))
  (setq XOrd(/(car 3dPos)divDid))
  (setq XOrd (car 3dPos))
  ); end if
     (if(/= 0.0(cadr 3dPos))
  (setq YOrd(/(cadr 3dPos)divDid))
  (setq YOrd (cadr 3dPos))
  ); end if
     (if(/= 0.0(nth 2 3dPos))
  (setq ZOrd(/(nth 2 3dPos)divDid))
  (setq ZOrd (nth 2 3dPos))
  ); end if
     (setq 3dPos(list XOrd YOrd ZOrd))
 (setq exCir
   (vla-addCircle actSp
     (vlax-3d-Point startPt)
     (/ pipe:exDia 2)))
 (vla-put-Normal exCir(vlax-3D-point 3dPos))
 (setq cirEnt(vlax-vla-object->ename exCir))
 (command "_.extrude" cirEnt "" "_p" pathEnt)
 (command "_.erase" cirEnt "")
(if(= "Yes" delFlag)
   (vla-delete baseLine)
      ); end if
  ); end foreach
      ); end progn
     ); end if
   ); end  of c:xpipe
(defun c:xtube(/ 3DPOS ACTDOC ACTLAY ACTSP BASELINE
         BASESET DICOUNT DIVDID EXCIR EXENT
         EXTUBE INCIR INENT INTUBE LAYST
         OBJTYPE OLDECHO oldWidth oldHeight
         STARTPT XORD YORD ZORD DELFLAG *ERROR*)
 (vl-load-com)
   ); end of *error*
 (if(not tube:Width)(setq tube:Width 40.0))
 (if(not tube:Height)(setq tube:Height 37.0))
 (setq actDoc
       oldWidth tube:Width
  oldHeight tube:Height
  ); end setq
   ); end if
 (setq tube:Width
   (getreal
     (strcat
       "\nSpecify external diameter <"(rtos tube:Width)">: "))
      tube:Height
   (getreal
     (strcat
       "\nSpecify internal diameter <"(rtos tube:Height)">: "))
  ); end setq
 (if(null tube:Height)(setq tube:Height oldHeight))
 (if(null tube:Width)(setq tube:Width oldWidth))
 (if(< tube:Height tube:Width)
       (initget "Yes No")
  (setq delFlag
 (if
   (setq baseSet
                             (mapcar
           'cadr
     (setq baseLine
           3dPos
          diCount(strlen
           (itoa
        (apply 'max
         (mapcar 'abs
      divDid "1"
      ); end setq
   (repeat diCount
  ); end repeat
  ); end if
  ); end if
  ); end if
 (setq exCir
     (/ tube:Width 2))
  inCir
     (/ tube:Height 2))
  ); end setq
 (vla-put-Normal inCir(vlax-3D-point 3dPos))
 (setq exEnt(vlax-vla-object->ename exCir)
  inEnt(vlax-vla-object->ename inCir)
  ) ; end setq
 (command "_.extrude" exEnt "" "_p" pathEnt)
 (setq exTube(entlast))
 (command "_.extrude" inEnt "" "_p" pathEnt)
 (setq inTube(entlast))
 (command "_subtract" exTube "" inTube "")
 (command "_.erase" exEnt "")
 (command "_.erase" inEnt "")
      ); end if
  ); end foreach
      ); end progn
     ); end if
    ); end progn
   (princ "\nInternal diameter more or equal external diameter! ")
   ); end if
   ); end  of c:xtube
ASMI:
While I'm sure the two LISP programs work beautifully it begs the question, "Isn't that a bit over-the-top?"
How about drawing the I.D. and O.D. in plan view, use the Region and Subtract (Solids) command, then changing the UCS and drawing the centerline of the exhaust pipe. Radius the bend at the top and then extrude the circles along the "path"? Slice the exhaust pipe at the appropriate point along the curve. Done.
I think your LISP programs might be more suitable to someone doing a lot of piping runs. Just an observation...not a criticism. Please point out the error of my ways should I be mistaken. I can always benefit from learning something new. Thanks.
>ReMark
I draw sprinkler systems and I should draw hundreds pipes a day. Therefore XPIPE which allow to draw many pipes per time help to me very much . XTUBE I have written simply so.
ASMI:
Thank you for that explanation. As I suspected, you need to produce a good deal of piping runs in a short period of time. Your LISP program gives you that capability. I appreciate that you shared it with us.
Hello
I got Acad to load the lsp that are posted in here, but don't know how to get them to run :oops:
Could you tell me what I need to draw to get the lsp to work, I drew a polyline and a circle at the end of it reprecenting the diameter i needed but all I got from both lsp was
"; error: An error has occurred inside the *error* functionbad argument type:
VLA-OBJECT nil"
Any help is greatly appreciated
Regards
Atli F.
>sibbles
You use what version AutoCAD? Can be 2000 or 2002? I unfortunately do not have such version, but try this:
         ZORD *ERROR*)
 (vl-load-com)
     (if(= 16(Asmi-AcadVersion nil))
   ); end if
   ); end of *error*
 (setq actDoc
       oldDia pipe:exDia
  ); end setq
   ); end if
 (setq pipe:exDia
   (getreal
     (strcat
 (initget "Yes No")
  (setq delFlag
 (if
   (setq baseSet
                             (mapcar
           'cadr
     (setq baseLine
           3dPos
          diCount(strlen
           (itoa
        (apply 'max
         (mapcar 'abs
      divDid "1"
      ); end setq
     (repeat diCount
  ); end repeat
  ); end if
  ); end if
  ); end if
 (setq exCir
     (/ pipe:exDia 2)))
      ); end if
  ); end foreach
   ); end if
      ); end progn
     ); end if
   ); end  of c:xpipe
 (vl-load-com)
   ); end if
   ); end of *error*
 (setq actDoc
       oldWidth tube:Width
  ); end setq
   ); end if
 (setq tube:Width
   (getreal
     (strcat
      tube:Height
   (getreal
     (strcat
  ); end setq
       (initget "Yes No")
  (setq delFlag
 (if
   (setq baseSet
                             (mapcar
           'cadr
     (setq baseLine
           3dPos
          diCount(strlen
           (itoa
        (apply 'max
         (mapcar 'abs
      divDid "1"
      ); end setq
  (repeat diCount
  ); end repeat
  ); end if
  ); end if
  ); end if
 (setq exCir
     (/ tube:Width 2))
  inCir
     (/ tube:Height 2))
  ); end setq
  ) ; end setq
      ); end if
  ); end foreach
      ); end progn
     ); end if
    ); end progn
   ); end if
   ); end if
   ); end  of c:xtube
(defun Asmi-AcadVersion(Generation)
 (if Generation
   (substr (getvar "ACADVER")1 4)
   (substr (getvar "ACADVER")1 2)
   ); end if
 ); end of Asmi-AcadVersion
  • 1 year later...
ok, sorry to be late to the party, but xtube works good for me. The only question I have is when 2 tubes come together, how do I trim the parts of the tube I do not want?
Thanks
Rusty
  • 3 years later...
  • 2 years later...
does anyone out there know the command for 'xpipe? (xpipe) does not work
You have to save the lisp on you pc first "name.lsp"
The use "Appload" to load it or simply drag and drop the file the drawing area
then you shoud get Command: (LOAD "C:/Users/xxxx/Desktop/test.lsp") C:XTUBE
now you can type xpipe or xtube and follow the command line
The xtube and xpipe seem great. only thing is when i try to use xtube i works the same as xpipe. It does not put a channel in the tube but just makes a pipe to the OD. Anyone know whats wrong?
