rcajelais Posted August 20, 2010 Share Posted August 20, 2010 Hi, (please note that english is not my first language ) I had this problem before, i thought I've fixed it but now it's back! When i do a plot, some lines are missing on the hard copies. I can see them in the preview, i can see them if i plot to a PDF, i even installed a PLT to DXF converter and the lines are there, but, they just won't show on my hard copy! Also, it's not always the same ones that don't print. Is anyone once had the same problem and figure out a solution? I use 2010 on a XP machine, the actual plotter is a Xerox 8825... Merci Beaucoup! Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 20, 2010 Share Posted August 20, 2010 Try running the plot again immediately after the first plot with the missing lines. I've been having the same problem lately. Usually the second plot turns out OK. I've tried switching drivers, cables and ports but nothing seems to work 100% of the time. Must be global warming. Quote Link to comment Share on other sites More sharing options...
rcajelais Posted August 23, 2010 Author Share Posted August 23, 2010 I did try that but the results was almost the same as the missing lines moved to somewhere else! I did found something once about a lineweight misunderstanding from AutoCAD but i can't find it anymore... Global Warming???? Ya maybe... It could also be Obama's fault since he is a socialist and a Muslim... and because he was born in Kenya. Anyway, if anyone thinks of something: pe-lease let me know! Quote Link to comment Share on other sites More sharing options...
