Hello,
I wonder how to combine the following sentences togather !
Select a Text please:
(setq txt (ssget '((0 . "TEXT"))))
Thanks.
Thanks a lot.
will it be things like this ;
(setq no (getvar 'nomutt))
(setvar 'nomutt 1)
(prompt "Select a Text:")
(setvar 'nomutt no)
Regards,
I think (setvar 'nomutt 1) should be under the prompt.
Lt Dan's Legs are correct.
[color=red](setvar 'nomutt 1)[/color]
(setvar 'nomutt no)
Thank you gentlemen.
I knew that correction, because I tried it on the second day.
I have no comments.
Tharwat
RenderMan
I am so happy to hear from you here in the CADTutor.
My best regards,
Tharwat
It's too bad you didn't post the corrected code back then, when you *noticed*, for others to see. :ouch:
Just kidding, I know you didn't mean to do that! :P
RenderMan
My best regards,
Tharwat
Thanks, man... I thought I'd branch out a bit 8)
