problem in writing the selected text info to txt file
Dear friends,
Greetings
Thanks for your support.
I have written a program for my requirement, i am facing some problem in exporting the text to txt file.
My requirement is i would like send information of the drawing with comma. I have taken our friends help to export the co-ordinates of pline vertices, i am able to send the selected polylines coordinates. but when i run my program pline vertex are exporting well. but the first selected text only exporting to txt file repeatedly, I think there is some problem with my logic.
i am attaching the drawing files also. when i select all the objects of the drawing the co-ordinates of the polyline along with its related text should goto txt file.
Please help me where i am going wrong.
Ramana
(defun c:test (/ ed v-lst fn pt str)
 (vl-load-com)
 (setq pl(ssget '( ( 0 . "LWPOLYLINE")))
   mtxt(ssget '((0 . "MTEXT")))
   PLNO(SSLENGTH PL)
   mtno (sslength mtxt)
   POS 0
   MTPOS 0
   PTLIST1(LIST "")
   fn (open "c:\\test.txt" "w")
   OUTPUT ""
 (REPEAT PLNO
   (SETQ BOOTH(SSNAME PL POS))
 (setq ed (entget BOOTH)
    v-lst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 10 (car x))) ed));list of vertices
   str "" str1 "")
 (foreach pt v-lst
   (setq x (rtos (car pt) 2 4)
     y (rtos (cadr pt) 2 4)
    str (strcat x "," y )
     str1 (strcat str1 "," str)  )
   ;(setq str (strcat x "," y ))
;CALCULATING CO-ORINDATES FOR TESTING TEXT
   (setq x (car pt)
     y     (cadr pt) )
 (setq ptlist(list x y )
   ptlist1(append ptlist1 ptlist))
         ); FOR EACH
(while (/= count 2)
 (SETQ
       MTEXT(SSNAME MTXT MTPOS)
   MTEXTinfo(entget MTEXT)
   MTXY(CDR (ASSOC 10 MTEXTINFO))
   MTX(CAR MTXY)
   MTY(CADR MTXY)
 (IF (AND (< MTX (NTH 3 PTLIST1) ) (< MTY (NTH 4 PTLIST1) )(> MTX (NTH 7 PTLIST1) ) (> MTY (NTH 8 PTLIST1) ))
   (PROGN (SETQ MTCONT(cdr (assoc 1 MTEXTINFO))
        COUNT(1+ COUNT)
        MTPOS(1+ MTPOS)
        )    (setq output(strcat output "," mtcont))
     (PROGN (SETQ MTPOS(1+ MTPOS)))
   );IF
   ); while
   (alert output)
(write-line (strcat output str1) fn)
   (SETQ pos(1+ pos)
     count 0
     mtpos 0
    output ""
     );PL REPEAT
  (close fn)
i
ext_text_layers(2).dwg
