saescavipica
Mouse frezees into the drawing after zooming in
saescavipica
Hi, well, here is my problem...
First of all, the mouse works propertly in anyother application, even inside autocad, but at the moment I zoom to a desired area and try to select an specific point or just draw in there, it lost his stability and starts freezing, which makes impossible to select that point..
I don't now exactly how to explain it, but I'll try.... if I quit the zoom, I can select the point, but I can't see it with such precission, if I zoom then the pointer can be positioned near around that point, but not in there!
It has happend a couple of times and it doesn't happen in all drawing, just in certain files, but it actually happens inside the same file but in different machines; I also tried using a different mouse with no different results; which lead me to believe the problem lies inside Autocad.
I'll give a little information about my machine, anyway, so let's see if it can help. I'm using Autocad 2010.
Machine Configuration
Processor Speed : 2.8 GHz
RAM : 3071 MB
3D Device
Name : NVIDIA GeForce 7300 SE/7200 GS
Manufacturer : NVIDIA
Chip set : GeForce 7300 SE/7200 GS
Memory : 512.0 MB
Driver : 6.14.0011.7519
Share this post
Link to post
lpseifert
Maybe your grid snap is on... try hitting F9 and see if that helps.
Share this post
Link to post
saescavipica
Thank you very much, it actually solved the problem! XD
Share this post
Link to post
