Hi all,
I am working on a lisp routine to automate print job. The printer that I have has 2 trays one loaded with A2 and the other with A3 paper. The problem is when taking print on A2 sheet we have to explicitly specify in the print dialog box to use tray 2 otherwise simply choosing A2 paper size does not work and the print comes out on A3 sheet. How to specify in lisp routine that tray 2 should be used for printing.
Thanks.
You might try using a page setup for each paper size you use. Look into using the ._PageSetup command.
Using LISP you can specify which page setup to use when you issue the print.
Hope this helps!
