AlexH Posted August 24, 2010 Posted August 24, 2010 When i add text on top of a viewport it always goes behind the viewports layers, I've tried to change the draw order to bring above objects but you cannot select anything inside the viewport. Also everything inside the viewports are Xref's if this makes a difference. Many thanks Quote
Slaraffenmann Posted August 24, 2010 Posted August 24, 2010 If you want the text on top of the viewport (Not inside), then try to click the viewport frame, and choose send to back. That should leave the text at the top. Did you make a new layer for the text? Quote
Dana W Posted August 24, 2010 Posted August 24, 2010 Check off 'Plot Paperspace Last' on your Page Setup Manager Quote
AlexH Posted August 24, 2010 Author Posted August 24, 2010 Thanks Dana, you're a life saver, i was giving up on it but your solution was spot on. Quote
Dana W Posted August 25, 2010 Posted August 25, 2010 Thanks Dana, you're a life saver, i was giving up on it but your solution was spot on. Glad I could help. Been there. Quote
