Hi,
I am having a problem justifying text that I create in a VBA routine. When I use this code:
If ThisDrawing.ActiveSpace = acModelSpace Then
   Set txtPNum = ThisDrawing.ModelSpace.AddText(strPNum, varPNumIns, dblTHeight)
Else
   Set txtPNum = ThisDrawing.PaperSpace.AddText(strPNum, varPNumIns, dblTHeight)
End If
txtPNum.Alignment = acAlignmentRight
txtPNum.Update
The text is inserted at 0,0,0
If I comment out the alignment line the text is inserted in the expected position.
I also have some MText that I insert and I can't seem to find a method to set its alignment. In the AutoCAD Properties window there is an alignment property. :-(
Has anyone else encounted these problems and does anyone see what I'm doing wrong?
Dave,
That works a treat for the text. Any ideas on the MText, it's not that important, but it's just bugging me.
Many thanks.
Thats ok.
Many thanks for your help.
