manirpg Posted August 26, 2010 Posted August 26, 2010 Dear friends, I need a lisp for find or select Touching (overlape) objects. Is there any way..........pls help me. Thanks in advance Actually I am working in Lighting layout, So i am receving architecture backgrounds, in this drawing more than thousand light fixtures are there,(circle or block) but i cant use this background directly for BOQ(quantity)and layout, because so many objects having more than single. some places one above the other (i can remove by overkill) some places not exactly above, slightly mis match (these case i cant use overkill, because i can't deside which one is correct without see) so i want to select these objects then delete manually. Please help anyone. Regards Mani:) Quote
manirpg Posted August 27, 2010 Author Posted August 27, 2010 Hi Alan, Thanks for ur reply, but FastSel is not exactly what i am searching......... In this case user have to select any one object, then select all objects. But my case user dont know where exactly overlaped objects available. Example: its available around 100 places out of 1000 objects Thanks Regards mani:) Quote
manirpg Posted August 27, 2010 Author Posted August 27, 2010 Hi Alan, your multi FastSel code very nice, very useful code Thak you Mani Quote
