Cut Fill Slope does not adjust TIN surface near corridor
So, I'm using this program for the first time in (2) years and have forgotten alot.
I'm trying to get the terrain on the surface around my corridor to fill and cut away as needed. After setting the alignment, the profile with a centerline guide, and creating an assembly with 2.00% 12.00' LaneOuterSuper, 1.25' BasicCurbGutter, 4.5' Sidewalk, and Daylight Cut Fill Slope with 2.00% Cut and 4.00% Fill, created the corridor by: Creat Corridor, Select Allignment, Select Profile, Select Assembly, Enter; and half of the corridor is embedded in the ground. What am I missing to adjust the terrain for the cut and fill? Is there another process I haven't done yet?
Thanks
Any good tutorial sites? I've followed the tutorials I've found through the help menu, but it still hasn't worked.
