Tharwat Posted August 30, 2010 Posted August 30, 2010 Hello. Is it possible to use only one an entmakex to draw the following four points without repeating the same entamex three time ? (setq p1 (getpoint "\n Specify a point :") p2 (getpoint "\n Specify a point :") p3 (getpoint "\n Specify a point :") p4 (getpoint "\n Specify a point :") ) (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2) ) ) Thanks. Tharwat Quote
fixo Posted August 30, 2010 Posted August 30, 2010 Are you talking about lines? (setq p1 (getpoint "\n Specify a point :") p2 (getpoint p1 "\n Specify a point :") p3 (getpoint p2 "\n Specify a point :") p4 (getpoint p3 "\n Specify a point :") ) (mapcar '(lambda(a b) (entmake (list (cons 0 "LINE") (cons 10 a) (cons 11 b) ) ) ) (list p1 p2 p3 p4) (list p2 p3 p4 p1) ) Quote
Tharwat Posted August 30, 2010 Author Posted August 30, 2010 Yes, My question was about draughting lines. Thank you so much fixo.That was great work. And could that be also possible with entmake "TEXT" or "MTEXT" ? Highly appreciated. Tharwat Quote
Lt Dan's legs Posted August 30, 2010 Posted August 30, 2010 (defun c:test (/ p1 p2) (repeat 4 (if (not p2) (setq p1 (getpoint "\n Specify a point :")) (setq p1 p2) ) (setq p2 (getpoint p1 "\n Specify a point :")) (entmakex (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2) ) ) ) (princ) ) ____edit___ Sorry, did not see fixo's response. scrolled right past it Quote
Lee Mac Posted August 30, 2010 Posted August 30, 2010 (if (setq p (getpoint "\nFirst Point: ")) (while (setq q (getpoint "\rPick Next Point: " p)) (entmake (list (cons 0 "LINE") (cons 10 (trans p 1 0)) (cons 11 (trans (setq p q) 1 0)) ) ) ) ) (defun line ( p1 / p2 ) (cond ( (and p1 (setq p2 (getpoint "\rPick Next Point: " p1))) (entmakex (list (cons 0 "LINE") (cons 10 (trans p1 1 0)) (cons 11 (trans p2 1 0)) ) ) (line p2) ) ) ) (line (getpoint "\nFirst Point: ")) Quote
Tharwat Posted August 30, 2010 Author Posted August 30, 2010 YES. Avery great works. But I meant the same routine that fixo had given me in his first post , which is making points that already made in a routine and to use only one entmake(s) to draught them all in one. So one question come up during that powerful codes that made by you gentlemen. Is it also possible to use one entmake(s) for TEXT ? Many Thanks. Tharwat Quote
Lee Mac Posted August 30, 2010 Posted August 30, 2010 You can use entmake to create almost any entity - Text included. You can only create ONE entity in an entmake call. Perhaps you are thinking of an LWPolyline. Quote
Tharwat Posted August 30, 2010 Author Posted August 30, 2010 Thanks a lot. I am thinking of text entmakex of all texts that already made in a routine. for example ; I have X , Y , Z with values, So how could I insert them by using one entmakex only. is that possible ? (setq x '10.0 [color="red"]y '20.0 z 30.0[/color] ) (setq pt (getpoint "\n Specify text location :")) (entmakex (list (cons 0 "TEXT") (cons 10 pt) (cons 40 (getvar 'textsize)) (cons 1 (rtos x 2 1)) )) Great thanks. Tharwat Quote
Tharwat Posted August 30, 2010 Author Posted August 30, 2010 Mybe with strcat function, it does not put them one on another , and "\n" also does not help in this case . (setq x '10.0 y '20.0 z 30.0 ) (setq pt (getpoint "\n Specify text location :")) (entmakex (list (cons 0 "TEXT") (cons 10 pt) (cons 40 (getvar 'textsize)) (cons 1 ([color="red"][b]strcat[/b][/color] (rtos x 2 1)[b][color="#ff00ff"]"\n"[/color][/b](rtos y 2 1)[color="#ff00ff"][b]"\n"[/b][/color](rtos z 2 1))))) Quote
Lt Dan's legs Posted August 30, 2010 Posted August 30, 2010 It would have to be (cons 1 mtext) and I'm not completely sure but I think you'll have to do \p Quote
Tharwat Posted August 30, 2010 Author Posted August 30, 2010 It would have to be (cons 1 mtext) and I'm not completely sure but I think you'll have to do \p YES .You're right. But I do not want use explode command to convert them into text . Here it goes. (setq x '10.0 y '20.0 z '30.0 ) (setq pt (getpoint "\n Specify text location :")) (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 10 pt) (cons 40 (getvar 'textsize)) (cons 1 (strcat (rtos x 2 1)"\n"(rtos y 2 1)"\n"(rtos z 2 1))))) Quote
Lee Mac Posted August 30, 2010 Posted August 30, 2010 Perhaps this will serve as an example: (defun c:mpt ( / MText norm pt ) ;; © Lee Mac 2010 (defun MText ( pt val norm ) (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 10 pt) (cons 11 (getvar 'UCSXDIR)) (cons 1 val) (cons 210 norm) ) ) ) (setq norm (trans '(0. 0. 1.) 1 0 t)) (terpri) (while (setq pt (getpoint "\rSpecify Point: ")) (setq pt (trans pt 1 0)) (MText pt (apply 'strcat (mapcar 'strcat '("X = " "\nY = " "\nZ = ") (mapcar 'rtos pt)) ) norm ) ) (princ) ) Quote
Lt Dan's legs Posted August 30, 2010 Posted August 30, 2010 sorry about the \p... I don't know why I thought that Quote
Tharwat Posted August 30, 2010 Author Posted August 30, 2010 Perhaps this will serve as an example: Really unbelievable. First. It is performing nicely . Second. Today I have been thinking to do a routine that would do the same you made in the last post. I feel speechless So you did two in one for me tonight. Thank you so much. Tharwat Quote
Tharwat Posted August 30, 2010 Author Posted August 30, 2010 sorry about the \p... I don't know why I thought that No problem at all. I do thank you for your kind sence of helping. Highly appreciated. Tharwat Quote
Lee Mac Posted August 30, 2010 Posted August 30, 2010 Really unbelievable. First. It is performing nicely . Second. Today I have been thinking to do a routine that would do the same you made in the last post. I feel speechless So you did two in one for me tonight. Thank you so much. Tharwat You're very welcome Tharwat, I'm glad you could find it useful Quote
Tharwat Posted August 30, 2010 Author Posted August 30, 2010 I have just realized when I checked it out with Vlide editor .And it returns as it's clear in the response of checking ... ; warning: local variable used as function: MTEXT Quote
Lee Mac Posted August 30, 2010 Posted August 30, 2010 I don't worry about those - it doesn't like local functions. Quote
