muck Posted August 30, 2010 Posted August 30, 2010 Is there a routine that allows a user to pick 2 points to erase objects crossing the window in VBA for AutoCAD 2010? Thank you, Quote
PeterPan9720 Posted September 18, 2010 Posted September 18, 2010 I use selection set Dim Block As AcadBlockReference For Each Paperino In ThisDrawing.SelectionSets If Paperino.name = "BOM" Then ThisDrawing.SelectionSets("BOM").Delete Exit For End If Next Dim PT1(0 To 2) As Double Dim PT2(0 To 2) As Double PT1(0) = 0# 'X PT1(1) = 0# 'Y PT1(2) = 0# 'Z PT2(0) = 170# 'X1 PT2(1) = 260# 'Y1 PT2(2) = 0# ' Z1 GC(0) = 0 GC(1) = 2 GV(0) = "INSERT" '--------------------------------------------------- 'Revise the block name "tendnum1" for your application GV(1) = "$Conf*" intCode(0) = 0: intCode(1) = 2: '--------------------------------------------------- ThisDrawing.SelectionSets.Add ("BOM") Set Ssnew = ThisDrawing.SelectionSets("BOM") Ssnew.Select acSelectionSetCrossing, PT2, PT1, intCode, GV For Each Entity In Ssnew Set Block = Entity BlockName = Block.name If Left$(BlockName, 5) = "$Conf" Then Block.Delete next Quote
