Lt Dan's legs Posted August 31, 2010 Posted August 31, 2010 quickly made a lisp and was wondering how do I remove the zero's (defun c:test (/ dist p1 p2 ent) (setq dist (rtos (distance (setq p1 (getpoint "\nSpecify first point: ")) (setq p2 (getpoint p1 "\nSpecify second point: "))) 2)) (setq ent (entget (car (entsel "\nSelect text to modify: ")))) (entmod (subst (cons 1 dist)(assoc 1 ent) ent)) (princ) ) examples of what I mean measurement 46.25 instead of 46.25000 or 42.375 instead of 42.37500. im not looking for (rtos dist 2 2) or ...dist 2 3) I'm looking for some sort of condition that changes the precision automatically. Quote
Hippe013 Posted August 31, 2010 Posted August 31, 2010 Try something like this: (defun set-prec (num / precn numstr) (setq li (reverse (vl-string->list (rtos num 2 (setq precn 12))))) (while (= 48 (car li)) (setq li (reverse (vl-string->list (rtos num 2 (setq precn (1- precn)))))) ) (setq numstr (rtos num 2 precn)) ) (set-prec 1.123456789000) returns "1.123456789" Quote
Lt Dan's legs Posted August 31, 2010 Author Posted August 31, 2010 I've tried to learn as much as I can using AUTOLISP but the call of VLISP is too great Quote
BlackBox Posted August 31, 2010 Posted August 31, 2010 (edited) You mean like this? (defun c:TEST (/ dist eName eData) (if (and (setq dist (vl-string-right-trim "0" (rtos (getdist "\nSpecify first point: ")))) (setq eName (car (entsel "\nSelect text to modify: ")))) (entmod (subst (cons 1 dist) (assoc 1 (setq eData (entget eName))) eData))) (princ)) ;_end defun See, in this case, when you use rtos without a defined precision, it returns the entire real number as a string (no matter how many decimal places). Now pair that with the vl-string-right-trim function, and you have a returned string that dynamically changes in decimal precision based on the distance. Edit: Without changing system variables Edited August 31, 2010 by BlackBox Typo Quote
Lee Mac Posted August 31, 2010 Posted August 31, 2010 You mean like this? Sorry for nit picking but (rtos nil) Quote
Lee Mac Posted August 31, 2010 Posted August 31, 2010 Should you want to avoid VL completely: (defun c:test ( / d s ) (if (and (setq d (getdist "\nSpecify Distance: ")) (setq s (ssget "_:L" '((0 . "TEXT,MTEXT")))) ) ( (lambda ( i / e ) (while (setq e (ssname s (setq i (1+ i)))) (entupd (cdr (assoc -1 (entmod (subst (cons 1 ( (lambda ( s ) (while (eq "0" (substr s (strlen s))) (setq s (substr s 1 (1- (strlen s)))) ) s ) (rtos d) ) ) (assoc 1 (entget e)) (entget e) ) ) ) ) ) ) ) -1 ) ) (princ) ) Quote
BlackBox Posted August 31, 2010 Posted August 31, 2010 (edited) Sorry for nit picking but (rtos nil) Please continue to nit pick, Lee... it's the only way I'm going to get better. :wink: Perhaps, this is preferable: (defun c:TEST (/ dist eName eData) (vl-load-com) (if (and (setq dist (getdist "\nSpecify first point: ")) (setq dist (vl-string-right-trim "0" (rtos dist))) (setq eName (car (entsel "\nSelect text to modify: ")))) (entmod (subst (cons 1 dist) (assoc 1 (setq eData (entget eName))) eData))) (princ)) ;_end defun Edited August 31, 2010 by BlackBox Added (vl-load-com) Quote
alanjt Posted September 1, 2010 Posted September 1, 2010 Please continue to nit pick, Lee... it's the only way I'm going to get better. :wink: Perhaps, this is preferable: (defun c:TEST (/ dist eName eData) (vl-load-com) (if (and (setq dist (getdist "\nSpecify first point: ")) (setq dist (vl-string-right-trim "0" (rtos dist))) (setq eName (car (entsel "\nSelect text to modify: ")))) (entmod (subst (cons 1 dist) (assoc 1 (setq eData (entget eName))) eData))) (princ)) ;_end defun (defun c:Foo (/ d e l) (if (and (setq d (getdist "\nSpecify distance: ")) (setq e (car (entsel "\nSelect MText/Text to modify: "))) (vl-position (cdr (assoc 0 (setq l (entget e)))) '("MTEXT" "TEXT")) ) (entmod (subst (cons 1 (vl-string-right-trim "0" (rtos d))) (assoc 1 l) l)) ) (princ) ) Quote
Lt Dan's legs Posted September 1, 2010 Author Posted September 1, 2010 To learn better methods, how can I improve on this code? Distance between points should be twice the distance between point and start/end (defun c:test (/ p1 p2 # ang ins) (setq dis (distance (setq p1 (getpoint "\nSpecify first point :")) (setq p2 (getpoint p1 "\nSpecify second point :"))) # (getint "\nSpecify number of evaps: ") ang (angle p1 p2) ins (polar p1 ang (/ dis (* 2 #))) ) (repeat # (entmake (list (cons 0 "POINT") (cons 10 ins) ) ) (setq ins (polar ins ang (/ dis #))) ) (princ) ) Quote
Lee Mac Posted September 1, 2010 Posted September 1, 2010 Not sure what you were talking about double distances, so just spaced them evenly... (defun c:test ( / p1 p2 a d ) (if (and (setq p1 (getpoint "\nSpecify First Point: ")) (setq p2 (getpoint "\nSpecify Second Point: " p1)) (setq n* (cond ( (getint (strcat "\nSpecify Number of Evaps <" (itoa (setq n* (cond ( n* ) ( 3 ))) ) "> : " ) ) ) ( n* ) ) ) (setq a (angle p1 p2) d (distance p1 p2)) ) ( (lambda ( i ) (repeat n* (entmake (list (cons 0 "POINT") (cons 10 (polar p1 a (* (setq i (1+ i)) (/ d (1- n*))))) ) ) ) ) -1 ) ) (princ) ) Quote
alanjt Posted September 1, 2010 Posted September 1, 2010 To learn better methods' date=' how can I improve on this code? Distance between points should be twice the distance between point and start/end (defun c:test (/ p1 p2 # ang ins) (setq dis (distance (setq p1 (getpoint "\nSpecify first point :")) (setq p2 (getpoint p1 "\nSpecify second point :"))) # (getint "\nSpecify number of evaps: ") ang (angle p1 p2) ins (polar p1 ang (/ dis (* 2 #))) ) (repeat # (entmake (list (cons 0 "POINT") (cons 10 ins) ) ) (setq ins (polar ins ang (/ dis #))) ) (princ) ) [/quote'] I did this one the other day (it will also return specified begin and end point)... (defun AT:DivideSegment (p1 p2 n) ;; Divide Segment ;; p1 - first point ;; p2 - second point ;; n - number of desired segments (must be > 1) ;; Alan J. Thompson, 08.19.10 (if (and (apply (function and) (mapcar (function vl-consp) (list p1 p2))) (> (fix n) 1)) ((lambda (a s i / l) (repeat (1- (fix n)) (setq l (cons (polar p1 a (setq i (+ s i))) l))) (cons p1 (reverse (cons p2 l))) ) (angle p1 p2) (/ (distance p1 p2) (fix n)) 0. ) ) ) Quote
