Trouble Lofting in Sheet Metal
Im having a bit of trouble lofting in sheet metal. Im getting an error message that says
Sheet Metal: Lofted Flange Creation failed.
Large Bin Access Door Flat Patern test.ipt: Errors occurred during update
Unable to thicken lofted surface
The attempted Shell operation was unable to solve for a vertex. This may have been caused by thin faces in the input or an overly large thickness. Try with a smaller shell thickness or by removing such thin input faces.
Feature Compute failed.
I am trying to do a ss sheet metal transition for a bin opening and i have my sheet metal set at 14 gauge with 5 degree facet angle. I have tried different sheet metal gauges and facet angles and nothing. Any help or suggestions would be appreciated thanks.
Any ....suggestions would be appreciated thanks.
Uhmm, zip and attach the ipt file here?
